So, what has that Swede been up to this summer?
Well, the swing cylinder is rebuildt, and the worn hole in the mount is fixed, so are a lot of other holes and bushings, the problem is that i can´t just replace bushings, because the holes they sit in have become to large and oval.
So first the holes have to be machined and larger bushings fitted, and larger tappets to go in the new bushings.
Here are some examples:
![Image](http://i718.photobucket.com/albums/ww184/d557017/S5030211.jpg)
Magnetic drill with a homemade tool that has a "cut" from a metal lathe on it, got the holes back to roundness.
![Image](http://i718.photobucket.com/albums/ww184/d557017/S5030205.jpg)
Had a friend machine this hole to roundness for me.
![Image](http://i718.photobucket.com/albums/ww184/d557017/S5030206.jpg)
First i put this piece in the lathe to make the part that goes in the hole round again, then i made a ring that i crimped on it, and finally i put it in the lathe again to make it perfectly round and make it fit in the new hole.
I have now worked my way to the end of the boom, currently waiting for new bucketcylinder seals, next will be the point where the stick attatches to the boom.
I plan to get a quickmount for the backhoe bucket, may be a S45 or B12,
don´t know if you use quickmounts?
If you do i guess they are called something entirely different then S45 and B12 ?
Ulf Jansson
