HYD REVERSER ON 350B
Donald erwin
I HAVE WITH THE REVERSER IT IS SLOW TO ENGAGE IN EITHER FORWARD OR
REVERSE CHECKED THE PRESSURE AT THE MANIFOLD ON THE SIDE AND HAD
LESS THAN 10 LBS OF PRESSURE IS IT THE PUMP THAT IS OUT
sisize]
sisize]
It could be a real toss up as it could also be the seals on the clutch pack shaft or the seals on the clutch pack piston . Deere built the piston housing out of aluminum and use a o ring seal.I would bet my time and money on the clutch pack piston seal as when one seal goes the whole unit works wrong.Digitup.
Finally back at my better computer .If you have been running the 350 for any length of time with that low of oil pressure to the clutch pack it should be rebuilt anyway as you need to have 120 lbs pressure at least or the clutch plates will warp I find Deere's steel plates warp faster than most but overall the clutch pack is better built .Digitup.
Donald erwin
hyd reverser
THANKS FOR THE INFO I HAVE BEEN TALKING WITH MY LOCAL JD REP
AND THEY SAME TO THINK THAT IT IS THE ACCUMALATOR AND RELIEF VALVE
ONCE I GET THUR THIS ICE TODAY PROBALBLY PULL OFF BOTH OF THESE ITEMS AND REBUILD THEM THANKS AGAIN DIGITUP IHAD THIS LITTLE CRAWLER FOR ABOUT 19 YEARS NOW PUSHED LOTS OF BRUSH WITH IT .
Donald erwin
reverser
HEY FOUND THIS OUT WHEN THE CRAWLER IS MOVING IT HOLD ABOUT 25 TO 30 LBS OF PRESSURE WOULD THIS STILL INDICATE PROBLEM WITH THE CLUTCH PACKS?
You still need a lot more than that for an operating pressure when you even move the crawler around you are damaging the plates with that little pressure as the clutch pack is slipping at that point and just warming up oil so watch it you need well into the 100 plus pounds of pressure or the friction plates are just slipping like crazy add a little work to the picture and you are just tearing the clutch pack up so get the pressure up and taking it apart and rebuilding the clutch pack is the best way to start .Digitup.
Users browsing this forum: No registered users and 117 guests
