350D radiator leaking
Just got a 350D and it has a leak from the radiator. What is involved in removing this radiator? Took a quick look before dark but was not sure how much needs to come apart. Thanks for any help
The front shroud actually pivots on two pins at the bottom. You need to remove 3 bolts down low on each side (5/8 or 3/4 if I remember correctly) and then 4 or 5 bolts underneath that connect to the belly pan. With those out it will pivot forward out of your way and stay there safely. I did this when I pulled my radiator, no need to completely remove it. After that, as long as nothing is too rusted up, it comes out easy.
1970 350 with a 93A backhoe attachment
Users browsing this forum: Google [Bot] and 28 guests
