![Question :?:](./images/smilies/icon_question.gif)
450c
450c
The pump in front of the engine is for hydraulic controls for either the loader or blade.
You might try running the brake/clutch adjustments for each track per the manual (if you don't have one download it!). It's a long shot but worth the effort before you pull the engine and/or transmission.
You cleaned the filter screen that is in the side of the transmission down low on the right side correct?
JD- 450C track loader
Serial #208336T
Serial #208336T
Hyd pump
Yes it is clean. I will adjust and try that before removing engine. I may have a winter project. Thanks (This machine has all new undercarriage and runs out great)
Users browsing this forum: No registered users and 90 guests
