Water pump on my 450
Hi, The water pump on my 450 has seen its betters days. It is leaking and after taking off fan it sounds noisy. I like to rebuild it . Can anybody Please enlighten me on the procedure ? Thanks Corteskid
I did a rebuild on my 350b pump. The parts are all available at Deere and, if it is the same as the 350s, you will need a press to push it apart and put it together. Not that hard to do but, you will need that service manual for the step by step instructions. About $90 on line for a download version (500 pages SM2064 is for the Deere 450 )
Welcome to the forum.
backhoe attachment.
backhoe attachment.
These threads may help you some:
http://www.jdcrawlers.com/messageboard/ ... water+pump
Water Pump on my 450
Thanks Guys, I shall tear into this pump - I found the info very helpful.Corteskid.
