JD 1972 (mid year) 350BB icd crawler loader MODEL 350BB
One of my 350s is stamped 350BB.Is this a double stamp or does it mean something ???? Serial 1491521
I'm not the best person to answer this, but I believe the second letter (A, B, or C) relates to the frame type and whether it is a loader or carries a blade. This does come up quite often as a previous owner will sometimes try to pass off (either intentional or unintentionally) a "B" model as a "C".
I think the thread discussing this has been deleted as I did a quick search but I know Lavoy or others will be able to definitvely answer that question- I do know however that it is not a "double stamping".The best way to tell is to actually look at the S/N (the "T" number) as that will tell you what you have.
It stands for diesel loader.....
BASIC TRACTOR SERIAL NUMBER
T23370 -UN-01JAN94
1. DIGITS 1 THROUGH 4 DESIGNATE THE TRACTOR 350B - JD350-B
MODEL.
2. DIGIT 5 DESIGNATES THE TRACTOR TYPE, FUEL A - GASOLINE, LOADER
AND TRANSMISSION. B - DIESEL, LOADER
D - GASOLINE, INSIDE DOZER WITH REVERSER
E - DIESEL, INSIDE DOZER WITH REVERSER
F - GASOLINE, OUTSIDE DOZER WITH REVERSER
G - DIESEL, OUTSIDE DOZER WITH REVERSER
H - GASOLINE, DRAWBAR TRACTOR WITH REVERSER
J - DIESEL, DRAWBAR TRACTOR WITH REVERSER
K - GASOLINE, INSIDE DOZER WITHOUT REVERSER
L - DIESEL, INSIDE DOZER WITHOUT REVERSER
M - GASOLINE, OUTSIDE DOZER WITHOUT REVERSER
N - DIESEL, OUTSIDE DOZER WITHOUT REVERSER
P - GASOLINE, DRAWBAR TRACTOR WITHOUT REVERSER
R - DIESEL, DRAWBAR TRACTOR WITHOUT REVERSER
V - GASOLINE, WIDE TRACK WITH REVERSER
W - DIESEL, WIDE TRACK WITH REVERSER
Y - GASOLINE, WIDE TRACK WITHOUT REVERSER
Z - DIESEL, WIDE TRACK WITHOUT REVERSER
3. DIGITS 6 THROUGH 11 DESIGNATE THE TRACTOR
SERIAL NUMBER.
4. DIGITS 12 AND 13 DESIGNATE THE T - JOHN DEERE DUBUQUE WORKS
MANUFACTURER OF THE TRACTOR.
T23370 -UN-01JAN94
MODEL.
SERIAL NUMBER.
backhoe attachment.
backhoe attachment.
