Drive sprocket clearance
I just replaced sprockets with an aftermarket sprocket and right side hits roller every half turn. will this just wear in or should I be concerned.
- lurch85
should be able to use shims to readjust it to get it back to between the roller edges. they are about 4 inch by two inch with a 2.5 inch semi circle cut out of them secured by two bolts. They are visible just in front of the sprocket if you are looking from the side. See your owners manual.
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
Would seem like something behind the sprocket so it is not flush with the hub.
Users browsing this forum: No registered users and 89 guests
