A few weeks ago I posted I had a stuck right clutch. I managed to free it up just by driving around the property. Worked great for a week. I had to adjust the power steering yokes as they were out of wack, then re-adjusted the clutch rod and brake. Driving it around today moving some firewood in the snow and the right drive started slipping. Found it really hard to maneuver. I managed to get back on firm ground and back to the driveway and parked. I adjusted again, the right clutch and the rod is almost all the way in, ie, can't make it any shorter. With the rod off the ball, there is no free play on the throw out bearing. The bell crank rod is free but there is no free play on the pressure plate fingers. Did something let go in here or do you think the clutch is toast? The left drives great, grabs really hard and never slips.
Is there anything I am missing and need to check?
Thanks.
350 loader stuck clutch freed..now it's starting to slip ARG
1952 MC
1965 JD350 outside blade
1968 JD350 Drott 4 in 1
1981 JD450C with 6 way blade and ripper
1965ish 710 green tractor
1978 212 garden tractor
2003 F525 circus mower
Forgot to mention that the left side adjustment rod is right in the middle of its' range, there is plenty of free play and otherwise seems 100% normal. I suppose someone could have changed one clutch and not the other....but who knows.
Thoughts anyone?
thanks
Thoughts anyone?
thanks
1952 MC
Users browsing this forum: No registered users and 69 guests
