boom cylinder
boom cylinder
john deere 350 loader hydraulic boom cylinder, how to remove from machine for repair what is needed to pull back pin?
1967 jd 350
were the pin goes through the cylinder towards the outside of machine you should find a bolt
If you are rebuilding yourself my 350c cylinder had a set screw and locktite holding the gland nut or rod guide.You may have to put heat on it .
68 350 loader
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
Users browsing this forum: No registered users and 95 guests
