jdeere 450e oil pan
jdeere 450e oil pan
Trying to get the oil pan on my dozer off without pulling the nose.I have the belly pan off and the oil pan broke loose but cant find a way to get it out of the machine.Trick here or what?????
Re: jdeere 450e oil pan
A little more info might help. Does the pan drop down to the ground or do you have the bolts out and it doesn't come loose from the engine?
You have to pull the hard nose. You are most likely held up on the oil pump sump. Never tried with the hard nose attached. There is only 6 15/16” headed bolts and comes off easy with a shop crane.
Users browsing this forum: No registered users and 97 guests
