Backhoe for 450b
Backhoe for 450b
Hi
i am looking for a Backhoe for my 450b Loader. Now there is one for sale on a internet Auction but the dont know wich type it is.
can anyone tell me the type from the pics and if it will fit on my loader?
https://www.ricardo.ch/de/a/bagger-heck ... 1043962268
thanks
Hansruedi
thanks
Hansruedi
Re: Backhoe for 450b
It look like a 95 Series to me, without the seat. The 95 and 95 SeriesA a advertised for the 350, 450, 400 series track type tractors. Check out the 95 backhoes on the net. Best regards, Bruce
Thanks Bruce
looks like that thing is mine now. as soon as its here i'm gona see if i can find some type plate.
i need a parts list and a manual or shop manual for it.
hansruedi
hansruedi
Hello hansruedi,
You should be able to access the on line parts book at https://partsadvisor.deere.com/ . Enter 95 in the model area and you should find parts catalog PC864. It covers the 93, 93A, 94, 95, and 95A models.
To purchase manuals you can go to http://www.johndeeretechinfo.com . Click the construction and forestry tab and you should get a drop-down list of models. Scroll down to the 95 and click on it. There you should find options for operators (OM) and service (SM) manuals in different languages. (SM2062 – English, SM3020 – French, SM3021 – German, SM2525 – Spanish, OMU40033 – English, OMU17508). These manuals cover the same models as the Parts catalog. You can get a parts catalog there as well if you want your own copy. There are several used JD manuals on eBay if you search the manual numbers.
I don’t know if you will need to go to other site(s) as these are the US links; I hope you can access them from your location. There are places at some John Deere sites where you can select your country. If you already have this info, sorry for the rehash of it. HTH. Good Luck and enjoy the new attachment.
hi Jim
thanks a lot for your information.
johndeeretechinfo works fine. i allredy have a acount there but somehow could not find the 95a.
but SM2062 works. guess i'l wait till that toy is here so i can see if (!) and how it works. that should be next week.
best regards
Hansruedi
best regards
Hansruedi
FYI, it may be the 95A but you better make sure it is in fact plumbed for an open center hydraulic system before you attach it to your 450B or you will blow your hydraulic pump or worse (i.e. sometimes people retrofit these for other applications)- 99% says it is what it looks like but my luck would be the 1%.
thanks, i'm gonna check that.
that backhoe finally arrived today. looks like it was standing out in the rain for the last 20 years. all the hose are rusted and broken. the levers also wont move. but there is nearly no worn.
still looking for a plate with type and serial number. does anyone know there it should have been ?
finally found the info. its 9500 and, acording to jd is not suposed to fit the 450 . we'll see.
The 9500 has a closed center hydraulic system and I believe that the 450B is open center (although someone should confirm that). Some replumbing would be required to not cause a dead end in the pump assuming open center. I believe some of the valve blocks on some hoes can be reconfigured but others would need to weigh in. That's also not considering whether the brackets will match up on both.
It does have the rotary swing cylinder ("donut") that does not have parts availability to fix but is a "slider" model that allows movement left or right which is neat.
