diesel fuel leaking into engine oil, JD450b
I was told today to get rid of mechanical lift pump cause the rubber diaphrams are cheap and cause leakage into engine oil. This guy told me to completely take the lift pump off and cover up hole and use electric lift pump. I had left the old pump in place and he thinks that diesel was still going through it and into the engine oil.
Re: diesel fuel leaking into engine oil, JD450b
Umbrella seal in the injector pump could be leaking.
If the internal components of the lift pump have failed and allowed fuel to leak into the oil sump(which is a fairly common failure) you either replace it or completely bypass it. If you still have fuel running through it, the fuel will continue to leak into the oil. Have you isolated the pump and tested it to see if it is the failure point??
Umbrella seals inside the injection pump are another area of concern.
Have you removed the fuel lines from the mechanical transfer pump? If the lines are off it, it can't put fuel in the base. If the active fuel lines are still on it, the pump would be my first place to suspect a leak into the base.
If the lines are off the transfer pump,the umbrella seals on the injection pump drive shaft are likely the fuel leak into the base.
Personally, I haven't had problems enough with the mechanical.pumps to make me want to install an electric pump. Each to his own.
- Jack-the-Ripper
I had diesel in the engine oil of my Case 580. I believe I tested the lift pump off the tractor by moving the "primer" lever while holding my finger over the input and output holes. Seems if the diaphragm is leaking it won't pump and hold pressure.
Turns out the leak was the input shaft of the injector pump, which is not rebuildable "at home." It cost almost $1k for a rebuild exchange.
Now to the point: I have a leaking injector pump on my JD 450C (it seems the 450B uses the same pump) which appears to be from the throttle shaft seal. After reading these highly recommended posts by jdemaris (who's apparently not on the board any more)
http://www.jdcrawlers.com/messageboard/ ... php?t=2571,
http://www.jdcrawlers.com/messageboard/ ... php?t=7121
I decided that our JD injector pumps are rebuildable with the right amount of experience and care, and the rebuild gasket kits as well as JD period correct injector maintenance manuals are readily available (and on order). I hope to post my results shortly.
MOST IMPORTANT: ONE OF THE LINKED POSTS EXPLAINS HOW AN INTERNAL PLASTIC RETAINER RING WITHIN THE INJECTOR PUMP DISINTEGRATES AND EVENTUALLY CLOGS THE WORKS LEADING TO LOSS OF POWER. When opening the first cover of my pump I discovered the aforementioned grit and realized I will have to rebuild the whole pump, gladly, and hopefully, for less than $50.
Users browsing this forum: No registered users and 47 guests
