Idler Bolt - Need to Replace
bulletpruf
Post by bulletpruf » Sat Jul 25, 2026 8:24 pm
'67 350 straight. Realized today that the idler on the right side was held on with a regular 3/4" bolt and no grease fitting, so it hasn't been getting greased.
The bolt is NLA new, so I'll have to source a used one.
A few questions -
-Can I just remove the current bolt and install a correct one? Or do I need to jack up the front of the machine and support it? Do I need to do anything to keep the idler and track from sliding off?
-How can I tell if the idler is junk?
bulletpruf
Re: Idler Bolt - Need to Replace
Post by bulletpruf » Sun Jul 26, 2026 7:02 pm
Disregard. For some reason, someone put the bolt with the grease fitting on the inside instead of the outside. I'll swap them around.
Post by Jim B » Mon Jul 27, 2026 4:56 am
Make sure the shaft was drilled completely through. some might only be drilled from one side. Just something to check. Pull the bolt out and run a wire in or pump some grease in the fitting and see if it comes out the bolt hole.
bulletpruf
Post by bulletpruf » Mon Jul 27, 2026 7:31 am
Yeah, someone mentioned that in the 350 Facebook group. I'll check that.
dabear3428
Post by dabear3428 » Mon Jul 27, 2026 9:54 am
A few questions -
and i thought you were going to send that bolt to your buddy down south with a lathe to drill it out for you lol
John Deere 350 straight
bulletpruf
Post by bulletpruf » Mon Jul 27, 2026 10:02 am
A few questions -
That would work, too. But I already have a spare on the way from Danne Moore in Vermont for $10 + shipping.
thanks
bulletpruf
Post by bulletpruf » Mon Jul 27, 2026 10:03 am
I found some pictures of the shafts for sale online and none mention that it's drilled completely through. Given how it's constructed, I strongly suspect it's only drilled on one side for grease.
Users browsing this forum: No registered users and 59 guests
