Back hoe for a 350
Back hoe for a 350
After reading about how over bearing a factory JD back hoe setup is on a 350, I was wondering if anyone ever tried attaching a back hoe from a skid steer. Being it would be smaller & lighter, I'm quite sure the 350 could handle it. Opinions?
years ago i put a Massey hoe on an old 310 case and i am about to put a 480 case hoe on my 2010 loader i would think a skid hoe would be just fine on a treefitty i believe both would be OPEN CENTER valves
Backhoe Options
We like the full sized 9550's on loader 350's, but when you get into a dozer they are just to heavy for anything but digging.
We have went thru a number of different smaller hoe attachments and now using a case hoe off a trencher, I believe it's a D125 (860 case trencher). It's on a 350C widepad dozer and works well. We installed a loader hydraulic pump and using the factory diverter setup. The hoe has stood up well and has enough power to push the machine forward and side to side.
Key to mounting is to get them as low and close to the machine as possible. I would say we have done at least 5 of them in the past 5 years.
Previously had smaller ditch witch and case hoes mounted and they didn't work as well. We buy lots of trenchers for wrecking and the hoes are always an easy sell. Have 3 in stock now, but I'm along ways away from you.
Not sure on the PTO comment, all hoes I have seen are powered off the front mount hydraulic pump.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Backhoes for a 350
I have one of the Case trencher hoes that Jason and his Dad modified to fit a 350 and I like it much better than the JD 92 hoe it replaced as it is probably 500 or more pounds lighter. It has good digging power and will dig to 8 feet deep and my 350 behaves much better when packing it around. With the old hoe my front end would lift climbing quite gentle inclines. The trencher hoe is actually a model 762. The D125 was used on 660 and smaller trenchers and some skid steers as well and is quite a bit smaller than the 762.
Anyone ever fit the 51 slider hoe from the 440 series on the 350? That always seemed like a slick hoe to have....
I believe from previous threads that Jdemaris had also converted hoe models from other manufacturers to fit on JD crawlers. You do have to make sure they are open center for the earlier crawlers.
Users browsing this forum: No registered users and 87 guests
