450C Hydraulics Not Working!
Hey all,
Using a 450C crawler loader with the multipurpose bucket and while using it the hydraulics went out. The machine will move forward and backwards but the hydraulic controls aren't even trying to move.
The operator added fluid, thinking that might solve the issue but after trying to run it again, we noticed there was no pressure being generated in the hydraulic tank.
Is it safe to assume the pump has gone out?
Thanks in advance for your help!
450C hydraulics
It is not uncommon for the splined coupling that connects the hydraulic pump to the pump drive on the engine to fail. If it worked 1 minute and not the next this is a likely candidate. If there was a slow noticeable decline in hydraulic performance it may be the pump.
The splines inside the coupler may be gone on the pump shaft end. So, you would see it turn, but it not be driving the pump. The couplers are made from a softer metal on purpose so they die and not damage the more expensive part.
If it just plain quit, this is what I would be looking for first.
I found the snap rings on the drive shaft but it seems to allow the coupler enough space to slide away from the hydraulic pump. I'm thinking this coupler has just been held in place for a while and then recently broke free with no roll pin to hold it in place.LeonardL wrote:There should be a spring pin / roll pin that goes through the coupler to prevent it from sliding away from the pump. There are also snap rings on the drive shaft itself.
I'll see what I can do about getting it back together and figuring that is the fix.
Thanks!
Users browsing this forum: No registered users and 109 guests
