Stuck Winch Cable 350b/arch
I did not notice the .5 inch cable had a birds nest when I tightened up on a pull with about 30' of the 100' of line out. Pulled a few logs and went to let out more line so to get safely out of reach of a big tree in case it came down on me, only to discover, how tight the over lap had become. I reset on a big stump and it will not pull out the overlap. I took a bit of a run on it in 2nd and no success. Stopped there as I do not want to break anything. Any suggestions ?
backhoe attachment.
backhoe attachment.
350 winch
Scotty, sorry to say but you will most likely have to cut the cable with torch or cable cutter.
that's one reason I only use about 75ft,, because they get tangled and get them out,, and it pisses me off to cut a good cable.. but that's life..
good luck Mark.
good luck Mark.
- Paul Buhler
Cold chisel, mason's pointed chisel, large screwdriver and a sledge make a good tool arsenal, a helper and some on again, off again, tension might get something wiggling. I've used my peavey to poke and pry as well. Some times I got lucky. Try hooking your cable up high in a stout tree and then try to pull it out. The different angle may get the strands to pass. Good luck. Paul
Mark, I think you are right. I will try to cut it with a small wheel on my angle grinder. Then bring the cable into the city and have the rigging guys press the logging hardware back on.
Perhaps I can get them to make me a few more Chokers with the short piece.
I seem to loose one or two of them every winter and, I could use one about 10 feet long for some of the larger logs.
on a related topic, I am hoping to drive out West before Christmas and pick up a winch for my 450c Dozer. It will be nice to have the dozer grousers once the snow gets a little deeper. In the meantime, we have had an exceptionally nice winter so far with just enough frost to work in the forest and freeze the small ponds. I did break through the ice on a creek today however I was able to get out on my own but it filled the undercarriage full of mud that will be frozen by now. Just another play day on the crawlers.
backhoe attachment.
backhoe attachment.
Paul, I will try to get it loose with the tools you suggested. If I take the cable out of the arch I might get to pull some other angles on the drum to help. Back in the city now (2 hours south of my equipment at the cabin) So on the next trip up it will be... get it loose or cut it out. I am going to make a trip West before I go back North so it will be a week or two before I can update on this .
Almost Christmas and I am a retailer so I will have to spend some time in there as well !
backhoe attachment.
backhoe attachment.
- Paul Buhler
350 cable
Wow you must have some big trees Scotty!! I have some JD winches for sale. 2 for a 450 and 4 for 350 if things don't work out...
One reason I cut the cable is it usually leaves a big kink in the cable and always frays at that spot... One thing you never want to experience is being in a hurry and grab a choker and run with it only to drive a steel fray right into your hand about an inch....
that brings you to a halt in a hurry!! of course you are in the woods so you have to pull it back out yourself..OUCH.. the quicker the better pain wise..
best of luck Scotty... Mark... sure sounds like nice country up there!
- Paul Buhler
Been there, done that. Not fun.One thing you never want to experience is being in a hurry and grab a choker and run with it only to drive a steel fray right into your hand about an inch.... that brings you to a halt in a hurry!! of course you are in the woods so you have to pull it back out yourself.. OUCH.. the quicker the better pain wise..
I run shorter cables as well. I don't like lugging the extra weight around when pulling cable to gather a hitch, and if you've got 100 feet on the winch, it's tempting to use more of it. Then there's the other issue of getting a straight enough pull with a lot of cable out so that you don't haul right into a rock, hollow or stump, and the stories can go on about all the mistakes I've made bunching and skidding logs.
[/URL[URL=http://s1058.photobucket.com/user/ascot ... e.jpg.html]
We are only a few miles into the forest line North of the prairie farmland however, due to all the lakes in the area and the National park just a short way away, no logging around here for a very long time. Our property is rolling hills half forested after the storm between the golf coarse on two sides and the public beach, totally Private except for the deer and other wildlife, we like being away from the beach and the crowd. Because of the spring fed creek I am working towards a nice pond and a few waterfalls as projects for the Deeres.
First my wife gets her new kitchen that is in progress now.
[URL=http://s1058.photobucket.com/user/ascot ... k.jpg.html]Some b[URL=http://s1058.photobucket.com/user/ascot ... 2.jpg.html][/URL
backhoe attachment.
backhoe attachment.
if it is ok, then I will post a little video. Even after you get it all cleaned up trees keep falling down.
That big stump was in the way of the trail and future bridge repairs so it had to go. threw a track trying to get it out of there with the 350b. The 450 loader got it out of there and it ended up on my burn pile.
backhoe attachment.
backhoe attachment.
Re: Stuck Winch Cable 350b/arch
[quote="Scottyb"]I did not notice the .5 inch cable had a birds nest when I tightened up on a pull with about 30' of the 100' of line out. Pulled a few logs and went to let out more line so to get safely out of reach of a big tree in case it came down on me, only to discover, how tight the over lap had become. I reset on a big stump and it will not pull out the overlap. I took a bit of a run on it in 2nd and no success. Stopped there as I do not want to break anything. Any suggestions ?
Scott[/quote]
I'm not a JD winch person yet. I have two winches on a 1956 Power wagon. My sons and I are obsessively careful with winch cable. I'd compare those winches to a bait casting reel. The brake serves only to prevent backlash on those winches. Keeping it at exactly the right tension to allow freewheeling without backlash is a balance Nick Walenda would understand.
Twice now wanna be operators have gotten to it. I've since put a key switch in, and a battery disconnect. My procedure is to attach the cable to a stump with a nylon sling to absorb some shock. Pull downhill, and gently bump the cable repeatedly. Stop frequently to check progress. Mine seems to gain inches at a tug, but not always. You may or may not free it this way. If you do, wind it in under quite a bit of tension, as in pulling a log up a hill. Then you need to evaluate. If too kinked, or at all frayed, replace. It's not worth dying over!
Scott[/quote]
An optimist is usually wrong, and doomed to disappointment. he is unprepared. A pessimist is usually right, delighted to be wrong, and is well prepared.
I tried to get this loose. Pry bars, punch and hammer, nothing was helping much so I just cut it out. I will be replacing the whole cable however, some sections will make good chokers.
Working without a canopy I like a lot of cable between me and these big leaners when I pull them over. This one leans over the convergence of 4 trails and a bridge. I want to pull it back over to the left before it falls and blocks all four trails and makes a big mess of the small spruce that have come up.
[URL=http://s1058.photobucket.com/user/ascot ... x.jpg.html][/URL
Has anyone tried using a synthetic cable/strap on one of these winches?
backhoe attachment.
backhoe attachment.
Synthetic rope on winches
I will second what B town said about using various rope alternatives on winches. We use a number of kevlar variants for longlines to sling under helicopters with. They are very light and handle much nicer than steel and are quite durable in straight line pulls, however they are very intolerant of abrasion like rubbing against something on a bent pull. If you inadvertently knot one and pull hard on it you will be cutting that piece out and making 2 lines, if you did manage to unknot it that section would be compromised and likely to fail in fairly short order. The stuff responds unfavourably to oil, grease, fuel, dirt and assorted chemicals and it is expensive. Much nicer to coil up and carry around that 100 feet of 5/8 steel cable though.
Steel Cable it is then. I am sure any cable on my winch will get grease, dirt, mud and all of that treatment so thanks for the heads up on the options.
I will be much more careful on long rewinds on a cable without a load to avoid the tangles.
On not having a canopy, I have lined up for one for my 350c, I just need time to get west and pick it up. Hopefully I will get that done and the winch moved over from the b before the log skidding work resumes in Feb. For now, I will get a new cable on and take down that leaner in the photos,(and one other that is over our ski trails). All the rest will just have wait.
backhoe attachment.
backhoe attachment.
Users browsing this forum: No registered users and 93 guests
