350 transmission noise?
- 40C crawler
Just acquired a 350 crawler loader with Diesel engine and reverser. It has steering issues and runs rough, so I have some work to do. Now my question is when I start it a loud noise resembling a bad bearing or something loose comes from under the floor boards, as soon as I increase the throttle from an idle it goes away. I know it's not easy to diagnose from my description but I thought I would just throw it out there. Thanks
https://scontent-ord1-1.xx.fbcdn.net/hp ... 3692_o.jpg
This is what the "RATTLER" style looks like --- if you are wondering.
https://scontent-ord1-1.xx.fbcdn.net/hp ... 0583_o.jpg
Last edited by cantbeatadeere on Sat Feb 13, 2016 7:03 am, edited 2 times in total.
Last edited by cantbeatadeere on Sat Feb 13, 2016 7:04 am, edited 1 time in total.
Yeppers all them links say "Sorry, this content isn't available right now."
- 40C crawler
No, pulling the power unit out of these crawlers is very easy(at least on the dozer models) If you look at the side pic with the springs you can see what the rattle is --- the small fingers that stick out under each spring at the flywheel surface come in contact with the dowel pins an cause the noise....the latest version is a thick rubber isolator that flexes and is quiet / more durable.
- 40C crawler
- 40C crawler
Users browsing this forum: Google [Bot] and 34 guests
