Water in transmission
I just purchased a JD 450 '70 model and it has water in the transmission. The service manual recommends to flush but does not say what to flush with. What do you experts use. By the way, this is a very informative board. I will probably have a lot of questions since this is my first dozer. Thanks in advance.
What DR meant was is it a straight 450 , 450B or 450C.... 1970 could be straight 450 or 450B ..... 450C would be 1976 and up..... If it is a "450" it is best to say its a "straight 450" stops the confusion
Yea that's what I meant to say.......jtrichard wrote:What DR meant was is it a straight 450 , 450B or 450C.... 1970 could be straight 450 or 450B ..... 450C would be 1976 and up..... If it is a "450" it is best to say its a "straight 450" stops the confusion
If it's anything but a C you have dry final clutches and will need to drain everything and leave the final drive plugs open to try and get all the moisture out. Do not flush the finals with anything. While you have the plugs out you may want to wire the control handles back so the final clutches don't rust and stick to the steels.
450C Track Loader
291457T
291457T
OP is asking about the transmission, I believe. The clutch houses did not have a common sump in the straight and B series, as stated the steering clutches should be dry. The C series can be converted to a common sump, i think some of the late C's came from the factory with common sumps, correct me if wrong.
Overall, I agree. If the is water in the steering housing- drain, tie handles back, don't put anything in there, and be very patient to let dry. I also think draining the trans and letting it dry on its own is the best. New filter, new fluid and a short cycle change. Take care, Bruce
The oil has additives that pick up water, so I just drain the old out and put in new. Then, change it again in short order. The oil changes color as the additives saturate, so that helps to know when to change it again.
To my surprise, I retrieved a pail of milky oil that I had put into a warm room in the basement last summer and, the water has settled out. It was fairly new oil before the water got into it and it looks good as new now. I had put it into a clear container or I might not have noticed and sent it to the recycle tank. Not sure if this always works but I will try it again next time I have milky oil.
backhoe attachment.
backhoe attachment.
water in oil
ScottyB,
I had a similar experience with a dozer 20 years ago. It had been sitting for 5 years. I knew water was in the oil, so I drained it.
As I recall, a small amount of brackish gunk came out first, then almost pure looking water came out first. Then to my amazement, out came what looked like brand new oil. I didn't reuse it, but probably could have.
So it's true. Let a mixture of oil and water sit long enough and they totally separate.
Stacy
Stacy
Stacy
