I am a new member of your forum although I have checked into it a number of time the last several years. I have a 350C loader that has been a reliable little work horse for several years. It recently shelled out the transmission so I now have a loader frame with a motor and reverser inside it and a sizable pile of parts. I am slowly gathering together the parts I need to rebuild everything but I have one issue I could use some advice on.
The clutch / brake drum has 3 grooves worn in the outside about 0.040" deep. My goal is to thoroughly rebuild everything so I never have to do this again (at my age that seems a reasonable goal) but I am kind of choking on the $1200 each new price so my questions are -
Has anyone turned down the band side of the drum?
Is there a minimum OD dimension for the band surface? I have a service manual with a lot of specs but I cannot find this.
Is it possible to get a thicker than stock band ling to compensate for the stock removed by turning?
Has anyone tried to weld up the grooves and then turn everything smooth?
Any advice would be greatly appreciated!
Don
Turning brake band drums on a 350C
On the dry clutch machines, I can get thicker line bands, but I am not sure on a wet clutch machine. I can check if you want, give me a call, or shoot me an e-mail.
Users browsing this forum: No registered users and 82 guests
