350b bogging out
350b bogging out
Im having trouble with my 350b, the machine starts fine, idles, runs through all the rpms fine while parked. But when it comes time to walk the machine will bog out while turning or when you go into a pile. Now it dies out while walking straight on flat ground. It also will bog out while going into a pile first gear wide open. I just changed all the filters drained the tank and reprimed the system, i cant figure it out. Any ideas?
Make sure there isn't something plugging the outlet from the fuel tank. Weird I know, but been there, done that.
Mine did not, if it had, most likely would have prevented the problem.
With Lavoy
I'm with Lavoy on this one. Had a diesel Ford 3000 doing similar. Checked everything imaginable and last check was fuel tank; found red shop rag in same. Now the tank is my first check!
Re: 350b bogging out
I assumed (may be wrong to do so) that with the statement above of the OP that he has fuel flow to the injector pump ..... that's why i said mouse turdsGulia116 wrote: I just changed all the filters drained the tank and reprimed the system, i
That would be my guess as well. That is how mine acted when the governor ring failed.jtrichard wrote:I assumed (may be wrong to do so) that with the statement above of the OP that he has fuel flow to the injector pump ..... that's why i said mouse turdsGulia116 wrote: I just changed all the filters drained the tank and reprimed the system, i
450C Track Loader
291457T
291457T
