Winch on JD 450b crawler
What oil to use? How much oil? Where is fill opening? Thanks.
I would use JD hydrualic oil or equivalent. I'm not sure how much,sorry. The oil is poured in the bung hole on the top right side of the winch. If it has been idle for any period of time, it may be helpful to remove the cast plate on the bottom right to clean the small pickup screen, before you put new oil in. Good luck, Bruce
What model is your winch?
winch on JD450 crawler
From the JD online parts list, I think the model on the winch is 3325. Where is the fill level? Thanks
winch - JD450b crawler
Thanks for info. I greatly appreciate it. Sounds like similar openings in bottom for drive trains to check oil level in them.
Users browsing this forum: No registered users and 132 guests
