Have my reverser out of my 350 dozer input and out put splines very worn purchased a new coupling and decided to to use 5/16 " spiral pins to secure coupling to splines both coupling and shafts are hardened steel was able to drill
them out using Bosh carbide drills available at Home Depot a set of 4 was $14
I drilled a hole in the top of the reverser housing above the out put shaft to drill the hole and be able to install the pin after installation of the reverser this the second time for coupling replacement hopefully the last !!
JIM
fix for drive coupling
Users browsing this forum: No registered users and 112 guests
