NEED HELP JD350C TRANNY PROBLEM
Good afternoon. I was working a BORROWED JD350C the other day and while working heard a POP and tractor quit moving. Engine still runs but no forward or reverse. Suspect output shaft broken. I am all ears as to how to go about making this repair. I am an experienced mechanic. Pull engine, go at it from the rear?
Pbrogdo
Pbrogdo
Pbrogdo
350C
6 way blade
rear winch
350C
6 way blade
rear winch
JD350C Tranny
I heard the engine has to come out to get to the tranny. I have also heard that I can get to it from the rear. I will also need a good manual, if anyone knows where I can get a good one or download a good one I would be grateful I am brand new to this forum and joined looking for help. All assistance will be appreciated. Pbrogdo
Pbrogdo
350C
6 way blade
rear winch
350C
6 way blade
rear winch
- Paul Buhler
Diagnose first to be sure, any tranny work is complete tear down.
My thinking would say 50/50 chance it is the isolator or the coupler. Big help there, eh?
If it is the isolator, then there would be no reverser operation. So, check that first.
In either case, you begin at the nose and work your way aft. These things are put together from the rear forward....
Tranny problem
Thank you for the head start. Now I just need a good manual. These manuals are expensive
Pbrogdon
Pbrogdon
Pbrogdo
350C
6 way blade
rear winch
350C
6 way blade
rear winch
The manual you need is TM1115 available down loadable from JD.com still
pricey Try Jenn Sales .I am assembling my 350 after replacing a leaking seal and a bad
coupling ended up drilling coupling and shafts with carbide drills and installed
5/16" roll pins to eliminate any more problems second time for me on
disassembly. you really do not need a manual if you do not need to get inside
the reverser it is just a matter of pulling it apart
JIM
JIM
Users browsing this forum: No registered users and 118 guests
