450c crawler fuel solenoid wiring
So I have a 450c cranks no start unless I put 12v to fuel solenoid, Does anyone have a wiring daigram ? I replaced ign switch thinking it was bad but no help . Would like too know how its wired so I can track down open wire or relay , fuse , etc to solenoid Thanks in advance for any help
- gregjo1948
Did you connect the solenoid to a constant "hot" post on the switch? I believe the solenoid requires 12v until you want to shut the engine down. Use the switch position that would be like the "ignition" position on your car.
Wiring is easy: from positive battery post to input of ign switch. Then wire from Run terminal of ign switch to fuel solenoid.
