bennyt
- 430 crawler
Post
by bennyt » Tue Apr 04, 2017 5:44 pm
Code: Select all
I am working on the steering clutch on a 450 plain. On the brake drum there is a tapered lip on one edge. Is this normal or is it supposed to be flat all the way across?
bennyt
- 430 crawler
Post
by bennyt » Sun Apr 09, 2017 12:51 pm
No one has ever seen a new one?
psprague
Post
by psprague » Tue Apr 11, 2017 10:00 am
Is it something like this?
bennyt
- 430 crawler
Post
by bennyt » Wed Apr 12, 2017 1:34 pm
taper is on surface where brake band runs 1/8" from edge to 1/8" high @ edge
bennyt
- 430 crawler
Post
by bennyt » Wed Apr 12, 2017 1:38 pm
is this wear or is it made this way
bennyt
- 430 crawler
Post
by bennyt » Wed Apr 12, 2017 1:41 pm
thanks psprague for the pic
psprague
Post
by psprague » Wed Apr 12, 2017 3:37 pm
It's a machined part. Does the edge have tool marks on it?
I'd have to say if it is worn, the brake must have been dragging alot. Is there heat or metal to metal damage? Is the band wear area flat? Is there any brake material on the band?
bennyt
- 430 crawler
Post
by bennyt » Fri Apr 28, 2017 2:06 pm
Sorry for the delay getting back on here. I've been busy with the arrival of my first grandchild @ age 70. It's a girl and she's a little doll. Now back on subject. The drum surface is smooth all the way across until it tapers up on the edge. I've never seen anything wear like this, but I guess anything is possible. Should I have it turned to make it flat all the way across?
Users browsing this forum: No registered users and 80 guests
