Are the final drives and the drive spockets the same on the JD350 and the JD350B?
Thanks,gregjo1948
final drive
- gregjo1948
final drive
Re: final drive
I think John DeMarris could probably give you chapter and verse on them. I see him on Yesterday's Tractor as "jdem" now. and I have his email as "wrenchalot at yahoo dot com". I bought a Case Manual for my 580CK from him when he was moving from NewYork to Michigan. For the email forget the quotes and spaces, etc.
- 40C crawler
Re: final drive
All 350 John Deere undercarriage is compatible across all 350 John Deeres. Same as all 450's up to and including the E series are compatible with one another. I'm sure there are some differences in idler mounting and track adjusters but entire assemblies are compatible.
- gregjo1948
Re: final drive
Thanks for the info. gregjo1948jwbcontracting wrote: ↑Fri May 12, 2017 8:14 pmAll 350 John Deere undercarriage is compatible across all 350 John Deeres. Same as all 450's up to and including the E series are compatible with one another. I'm sure there are some differences in idler mounting and track adjusters but entire assemblies are compatible.
Users browsing this forum: No registered users and 129 guests
