Jd 450c wiring harness
- 40C crawler
Where would one find a new wiring harness and new gauges.
- gregjo1948
Re: Jd 450c wiring harness
You may be able to get them at a JD dealer. You can get gauges at local auto parts. They just won't be JD.
Wiring harness would be Deere only far as I know. Gauges I might have some aftermarket that look close to the same. If you use aftermarket, you will likely have to change senders as well.
- 40C crawler
Thanks for the reply
looks like I will be making my own harness and buying the gauges, I think I will replace everything including the sending units.
Lavoy can you email me what you have and the price.
If you are replacing sending units, I would just use aftermarket gauges like Stewart Warner for example.
