350B reverse
- gregjo1948
350B reverse
My 350B moves forward as it should but, when going to reverse, it's slipping. Seems OK until there's a strain on it. (back blading or backing up hill) Is it in need of an adjustment or is the reverser failing? thanks, gregjo1948
Re: 350B reverse
My reverser gives me a problem also. In the down position it works fine but when you pull it up it hesitates a little then moves but makes a screeching noise while moving. Thought it would straighten out after using it for a while but never did. I just leave it down and shift the tranny most of the time. Read a post somewhere that if one side went out that you could use the other side but you have to shift gears all the time. It's a pain but it works for me.
Users browsing this forum: No registered users and 46 guests
