well fortune smiled on that project.....was able to drill and tap all three handles for set screws.. twas a bit concerned as all three are same size handle..only each has different hole size...which leaves the outer boss thinner on each as move inward to the dash...
Lavoy...i could not find the serrated or toothed set screws..so just used what tractor supply had available and if find the better ones will change em out if these don't hold....will find out when get to work it...used 5/16 by 3/8 ..20thread and each head consecutively higher inward.
hope this helps someone else solve problems..
thanks to all
dtoots1
Blade control handle assembly
Re: Blade control handle assembly
I thought you could drill a small hole thru lever and shaft for each one and install a small bolt w/nut or roll pin.
erased double post
well if you look at the pics you can see that each of these on mounted on separate tubes and a shaft...mounted one within each other...so no cannot put bolt or pin thru the boss .
http://jdcrawlers.lcent.com:8000/johnde ... 0_0445.JPG
http://jdcrawlers.lcent.com:8000/johnde ... 0446~0.JPG
both of these pics show the normal_ in the hyperlink...if you actually go to the dedicated pic server site you can view the larger size of all pics shown by clicking on pic itself.
now am gonna try to clean up the double post
