Hey
I was adjusting the steering clutch throw out on my newly acquired 450. The prior owner did not install any of the spherical washers on the adjustment bolts. John Deere is asking $13 each and I need all 4. The math does not look favorable. Is there a generic replacement? I still need to go fishing with a magnet in the clutch/brake box. Might find one or two of them down there.
John
Spherical washers for the steering clutch
Re: Spherical washers for the steering clutch
Cle, I found years ago when I had this problem.. that the bushing for the rocker arm on big block chevy motors is an exact replacement fit,, and I suspect a lot of small block chevys might also work.. it is right under the locknut for the rocker arm.. Mark
Thanks for the tip. I am picking up this job again. I may be able find a couple out in my junk pile.
John
John
Users browsing this forum: No registered users and 32 guests
