550 JD Dozer
550 JD Dozer
My 550 has water in transmission and brake/clutch, enough to make the water milky, it is indoors when not in use so I don't think its from rain, is the cooling tank under radiator where the leak is or does fluid from transmission actually travel up the core of radiator. I have no leaks external in the radiator it must be small. Does stop leak work in this situation.
Users browsing this forum: drssink, Google [Bot] and 102 guests
