350 reverser
- gregjo1948
350 reverser
As I stated in earlier posts, my 350 won't back up using the reverser after the machine reaches working temperature. It does seem to move OK with the reverser in the forward position. Will any damage be caused by running the machine with the reverser in forward position and the trans. in reverse gear? Thanks, gregjo1948
Re: 350 reverser
Won't hurt a thing. If system pressure is down, forward clutch may start to slip too, just be careful.
- gregjo1948
Re: 350 reverser
Thanks for reply.
This is the machine you got me parts for(for the reverser) last fall.
I just want to move it back into the shop for repair but, don't want to
make things worse by moving it in reverse that way. I couldn't see why it would hurt but,
what do I know. I'm the guy that must have messed something up when putting it together.
gregjo1948
Re: 350 reverser
Check all your pressures first, make sure the reverse pressure is up to spec. If not, that is your problem I would think..
Users browsing this forum: jimmydiesel and 121 guests
