Hi
I am doing a steering clutch/brake adjustment on JD 450(no letter). I am going through it step by step per the manual. Got a couple of questions:
When the manual says adjust free play, does it mean when the top linkage first moves or when the throw out bearing first touches the clutch? I believe they mean at the throw out bearing but maybe a guy with experience can verify.
What is the thickness of the brake lining when new? Is there a way to check the thickness while it on the machine? It all looks pretty well hidden.
Thanks for any help.
John
450 () Steering clutch/brake adjustments
Re: 450 () Steering clutch/brake adjustments
Free play is the distance traveled from top of the pedal to first contact with the throw-out bearing. I'm not exactly sure of the brake material thickness. A guess would be 0.250. Bruce
Thanks Bruce
That is the way I had it figured. First touch with the throw out bearing. It's complicated by the problem of a lot of slop in the linkage. It a will get done right.
Thanks again
John
Thanks again
John
Users browsing this forum: No registered users and 106 guests
