A couple of my roller grease fittings squeeze the grease back out of the zerk. Are these bad zerks that need to be replaced or is there a larger internal roller problem? Where to get new zerks if that's the problem?
1966 diesel 350, 5 roller.
350 roller grease fitting
Re: 350 roller grease fitting
The zerk has a ball right at the opening with a spring behind it. When the spring gets weak, it leaks. The thing is built such you can't fix it. So, you just replace it.
Ok I'll check out Napa
Users browsing this forum: No registered users and 52 guests
