Hello,
Replacing the ring and pinion in my 450C track loader. Bought one from Reliable After Market Parts in Michigan off eBay. Opened the box and the pinion shaft is much shorter than mine. I didn't even remove the ring gear from the box as this is obviously the wrong parts. Where do I get the correct ring and Pinion and does it have to be riveted back on or can bolts be substituted?
450C Ring and Pinion
Re: 450C Ring and Pinion
suggest you go directly to owner of this site...LAVOY..if he aint got it he can sure direct you!!!
Part number needed is AT30888.
try Lavoy first there many dismantlers you can search who have good used parts Machinery Trader, Tractor Part.com Wengers of Meyerstown AIS used Parts
good luckJIM
good luckJIM
Part number AT30888 is the ring and pinion set, with the ring gear rivetted to the included hub.
So you shouldn't need to install rivets.
On the other hand, the repair manual tells how to install the ring gear on the hub and properly smash the rivets.
Users browsing this forum: No registered users and 147 guests
