450C Hydraulic pump
Rincon
450C Hydraulic pump
Post by Rincon » Wed May 09, 2018 11:09 am
my hydraulic pump is leaking from underneath. Almost certain it is not the pipe or hose fittings. Has anyone replaced theirs ? mine is located at the bottom of the radiator.
B Town
Re: 450C Hydraulic pump
Post by B Town » Wed May 09, 2018 12:37 pm
Yes, I have replaced the pump. You may be tempted to remove the pump without removing the hardnose. To save yourself, it is easier to remove the hard nose and then work on the pump. Bruce
jsal
Post by jsal » Thu May 10, 2018 11:07 am
have a 45C also had a leak also, turned out the pressure swivel fitting was cracked replaced with new fitting all better.
JIM
77 Ford
Post by 77 Ford » Fri May 11, 2018 6:57 am
I just put a front seal in mine, it's a little early to call it fixed but so far so good. I have almost no play in the end shaft, I think the seal was just dry rotted.
JD- 450C track loader
Serial #208336T
Users browsing this forum: No registered users and 97 guests
