450C Hydraulic pump
450C Hydraulic pump
my hydraulic pump is leaking from underneath. Almost certain it is not the pipe or hose fittings. Has anyone replaced theirs ? mine is located at the bottom of the radiator.
Re: 450C Hydraulic pump
Yes, I have replaced the pump. You may be tempted to remove the pump without removing the hardnose. To save yourself, it is easier to remove the hard nose and then work on the pump. Bruce
have a 45C also had a leak also, turned out the pressure swivel fitting was cracked replaced with new fitting all better.
JIM
JIM
I just put a front seal in mine, it's a little early to call it fixed but so far so good. I have almost no play in the end shaft, I think the seal was just dry rotted.
JD- 450C track loader
Serial #208336T
Serial #208336T
Users browsing this forum: No registered users and 49 guests
