HLR pressure gauge.
HLR pressure gauge.
I want to put a permanent dash mounted HLR pressure gauge on a JD450(). Right now I have a gauge mounted to the port under the shift controls. When the outside cover (not the allen head pressure screw, the threaded disk) is removed I am getting a little oil splashing from inside the case and onto the floor. Is there another place that I can put a pressure tap? Preferably someplace with enough room to install an electronic sender unit with no additional plumbing.
John
John
Re: HLR pressure gauge.
I understand that some 450's actually came with a sender unit and gauge. Does anyone know where the sender was mounted? I see the gauge wiring in the parts list but I have no clue where sender is located.
John
John
I think mine might have had a transmission oil temperature gauge, or so the manual says.
Mine has the HLR temperature gauge also. The manuals seem to indicate there was also a pressure gauge also. Maybe it was only on a few units. I am trying to figure out where the sender was located.
John
John
On my 455D the access plug in the transmission top cover under the seat that lets you check transmission pressure has a pipe thread. I can't remember the size; same as a 55 gallon drum I think. I replaced the screw out plug with a short pipe nipple and screwed a pipe cap on the nipple. I drilled a hold in the cap so I could run a nylon tube from the test port (1/8 NPT Female, I think) under the floorboard to the back of the dash. I cut a hole in the dash and mounted a 2" 0-200PSI mechanical gauge with a restrictor to dampen the pressure pulses.
Farmerford
Columbus, Georgia
Columbus, Georgia
A tube to the top pressure port was my "plan b". I was hoping to find a place to mount an electronic sender and there is no room for a sender under the cap. Plan B is starting to look better.
If that cover really is the same as a 55ga drum hole cover I can drill a hole in it, use an extender and mount an electronic sender below the HLR controls. I don't want to drill holes in the original cover. Call this Plan B Rev 2. I still wish there was a better pressure port.
I, for one, do not want a high-pressure high-temperature oil line, down around my feet, pointing upward, to fail. Just no.
I have had bad experience with the oil tubes leaking and making a mess in a reasonably nice car. I am not bad with a electric sender running up to a gauge provided it is not in an area likely to get damaged. I am going to take a second look at it to see if there is room.
