Well, we found another machine and are mainly interested in the 6 way blade it comes with. It’s a 350BE which tells me it came as an inside blade from the factory, s/n tells me 1971. We have a very nice ‘65 350 with the 6310 blade. The machine in question is in pretty rough condition, runs, moves and all seems to operate, we would like to move the 6 way to our “good” machine.
Several questions...
1. Will the current 6310 hydraulic pump support the 6 way?
2. Are all the holes drilled on the ‘65 machine to allow easy mounting of the 6 way?
3. Control valve holes drilled or common with the 6 way and 6310 machine?
I don’t know how the 6 way attaches to the machine, i’ll try to find some pictures tonight but will it mount to the dozer frame without any modification?
My guess is we can get it for less than $3K, and I guess depending on what the machine needs we may just leave the six way on it and restore it as another reliable machine, will post some pics when I get back on my computer.
Thanks for your help.
Cheers
Will inside 6 way blade transfer to manual blade machine
1952 MC
1965 JD350 outside blade
1968 JD350 Drott 4 in 1
1981 JD450C with 6 way blade and ripper
1965ish 710 green tractor
1978 212 garden tractor
2003 F525 circus mower
Re: Will inside 6 way blade transfer to manual blade machine
All of the above SHOULD work.
Thanks, in the last few days I managed to find pictures of the mounting points for the 6 way inside blade, now I just need to make a deal on the machine and get it home. Will post some pics shortly.
1952 MC
Users browsing this forum: Google [Bot], rbp and 89 guests
