Lost power to one side of my 350
Hello all. I currently have a 65 jd 350. I was pushing with it the other day and lost power to the left side. Figured the clutches went out so replaced them plus pressure plate. I still have no power to that side. Seemed like I had it briefly but then nothing. Am I missing something? I adjusted the fingers on the pressure plate as well with the jd gauge. I'm needing my machine so if anyone has any ideas please throw them out there.
Re: Lost power to one side of my 350
Assuming you adjusted the clutch "by the book" then you are about to pull the final again. First remove the access cover above the clutch (where you made the clutch and brake adjustments after installation). See if anything moves when in gear, forward or reverse, with the other steering clutch handle tied back or at least pulled. If it does then the problem is outboard (like maybe stripped splines between axle and bull gear). If nothing moves then the problem is inboard. Then pull the final and repair the problem. If you pull the bull gear cover and have someone watch the gear under the same test conditions you will know for sure whether you have an axle problem. Clutches rarely fail suddenly. They usually slip a while first.
Thanks for the reply. I never got the track back on it yet so won't be too bad to get to. I was kinda thinking it might be in the final but was hoping not. Will check it out maybe tonight.
Well checked everything out and the brake drum wasn't turning with that side off the ground the other side tied off. Band was loosened up and steering lever completely unhooked. Tore it all apart and double checked it all and all looked good. Put it back together and fired the dozer up and tried it without the sprocket. It turned for a minute then nothing. I can see the pressure plate wanting to turn but is slipping. Could the brake drum be wore to the point it won't let the clutches grip? The outside where the brake band runs is wore pretty bad.
Parts book shows eight fiber and seven steel plates. It assumes you will be using good parts, like you get from Lavoy. If you got the internet junk all bets are off. I cannot imagine the clutch side of the drum getting that worn, especially in a hurry. If the shaft is turning but the drum is not it is most likely adjustment, lack of thickness of plates, or six broken springs in pressure plate (there are two springs in each position, one inside the other). Make sure the shaft is really turning. Can you turn the sprocket hub with a bar and two bolts? If you can then you can more safely see if the shaft is turning that way.
When I first put it together I have to use a bar to turn it but then it's like it lets loose and I can turn it by hand. The pressure plate is new and triple checked. I can see the drum trying to turn but won't. I think I'm going to check the thickness of my new clutch disc.
Well I figured out I need the hub the ring gear mounts to. How big of deal is that to take out. I assume I have to pull both sides apart then the rear end.
You mean the Spool which sits where the differential would be on a wheel tractor? Yeah. That is a drop both finals and remove the side boxes and seat kind of operation.
I have never seen a hub strip out alone. Usually the shaft is broken or the splines toast on both shaft ad hub. You need to pull the right side to get the hub and ring gear out, as I recall. You can check the hub splines easily before puling the right side since the left track is still broken.
Yeah I missed the spines the first couple times I pulled the left side apart When the issue continued I new it had to be something else. The spines to the outside of the hub are good so really had to look in there to see. The shaft is fine surprisingly. Anyone know where I might find a hub? Can't find just the hub online or a ring gear with hub.
My experience with ring and pinion gears has been in heavy trucks and a loader or two. Those were sold, and we replaced them, as matching sets. Never had to do a crawler, but the parts are the same. In the parts catalog it looks like as a set, was the way JD sold them as well. Mating fits of the gears, causing accelerated wear, and noise were concerns with mismatched sets. You can likely get away with using a different ring gear against your pinion, I don't think it would be ideal by any means, but I expect it would work. It has been done before. Someone here likely will have some insight on that.
That said, do you see any numbers on your hub? The 350 parts catalog references hub marked T11388. The parts catalog shows this same hub in some 440ICs and 350Bs, it might have been used in others as well. The same 37 tooth ring gear part number (T11365) shows up in those machines as well. The pinion numbers are different. It does look like the rivets to attach the ring gear to the hub, are still available from JD. Just passing it on as using the part number(s) you are looking for might open up other sources to look at, rather than just saying a 350. I looked at the MY Nortrax site and they show an aftermarket kit with a part number of AT18442U which might be for a 350 as the catalog shows AT18442 as the part number. No info to confirm my thought that this is the right kit nor a price.
Have you sent Lavoy an email (postmaster@jdcrawlers.com)? He may have an idea on used or a source for an aftermarket hub. Hope this helps, good luck.
Yeah lavoy didn't have anything. I can use my ring gear with the hub that is with the ring gear I found. I think I would bolt it instead of rivets though.
If you bolt it, I think you need to find bolts that are at least size for size to the holes or maybe a .001" interference so no movement can get started between the hub and gear.
If the ring gear carrier does not have two dowels in it, I would have it riveted. A bolt does not fill the hole, and they will eventually break from the back and forth.
Any of you guys have any pointers in getting throw out bearing fork out of steering clutch housing? I took the set screw out but it isn't budging. I even used heat.
Users browsing this forum: No registered users and 138 guests
