Snow-Cut Pads for my '99 450G
Al Swearengen
Post by Al Swearengen » Mon Feb 11, 2019 4:58 pm
Any leads on best price/availability? This damn popping is now more than I can tolerate after this big storm (SALT rails, new sprockets installed about 200 hours ago---didn't have enough $$ to swap out the pads then).
'99 450G 6-Way
Al Swearengen
Re: Snow-Cut Pads for my '99 450G
Post by Al Swearengen » Tue Feb 19, 2019 5:14 pm
Well I can't source them anywhere. Any idea what a ballpark figure would be to have my pads regroused at a shop...and wondering if they would also be set up to cut the hole?
'99 450G 6-Way
Post by Jim B » Tue Feb 19, 2019 7:34 pm
It looks like T127057, single bar, 16", open center, shoe for 9/16" bolts is available from John Deere. The place you got your chains can't help you?
You would need to ask the shop you want to use to do the grousers if they are set up to cut your pads. Likely a fab/welding shop would be. I think a plasma cutter would put the least heat into them for cutting the center holes. That said, I wonder if you will see breakage if you cut the holes in them.
Al Swearengen
Post by Al Swearengen » Wed Feb 20, 2019 9:06 am
Thank you for the part number! The local dealer (PAPE) had no clue...called them Friday, said they would research and get back to me. Looks like I can now help him with your help! I chose Berco SALT for my rails, never called them...maybe should try.
https://www.greenpartstore.com/John-Dee ... 84712.html
'99 450G 6-Way
Post by Jim B » Wed Feb 20, 2019 10:43 am
I figured you had already checked with your track supplier. It would seem Berco should have them, they are mentioned in some of their literature. Where and the lead time might be the question.
The shoe options are listed in the track groups of the John Deere parts catalogs. But if you didn't buy from them they may not be as inclined to help you. Here is a link to one of the track group pages. https://partscatalog.deere.com/jdrc/sid ... gId/656416
Al Swearengen
Post by Al Swearengen » Wed Feb 20, 2019 1:50 pm
Thank you so much for your help!
'99 450G 6-Way
NWJD fan
Post by NWJD fan » Wed Feb 20, 2019 11:03 pm
Prior owner of my 450C looks like he cut relief holes in the pads with oxygen acetylene
Al Swearengen
Post by Al Swearengen » Thu Mar 28, 2019 11:22 am
TREK brand undercarriage products any good? Finally got a quote, but never heard of that brand...warranty for 3 yr/4000 hr.
'99 450G 6-Way
Post by Jim B » Fri Mar 29, 2019 5:39 am
I've heard the name and seen some ads but can't say I have knowingly seen their product. Will they give you any references that are using their undercarriage components you could contact?
Al Swearengen
Post by Al Swearengen » Sat Mar 30, 2019 6:10 am
Good idea...been researching what I can find, seems they all rate about the same.
'99 450G 6-Way
JWB Contracting
Post by JWB Contracting » Sun Mar 31, 2019 7:27 am
Trek Brand. We have been using it for 15+ years. Rails held up great on our widepad 350’s. Never had any issues with their rollers or sprockets.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Al Swearengen
Post by Al Swearengen » Sun Mar 31, 2019 5:05 pm
Thanks for your feedback. That agrees with everything I have found also. I'll be ordering a set tomorrow!
'99 450G 6-Way
Al Swearengen
Post by Al Swearengen » Mon Dec 02, 2019 9:38 am
Well that was a great lead for me! Thank you! While they didn't have pads with the holes cut, the company sent them out for me for plasma cutting then shipped to me. Couldn't be happier! Pushed my first snow the other day and they completely solved the problem! No more sprocket jumping!
'99 450G 6-Way
Users browsing this forum: Google [Bot] and 35 guests
