Bristol Wrench
Bristol Wrench
Going to order a Bristol wrench to rebuild my injector pump and is the correct size 0.48 6 spline? Can't seem to find that info anywhere. Must be top secret. Lol
Re: Bristol Wrench
Just asking this as we don't have any knowledge of your background working on injection system components. What is wrong with your injection pump? Do you have the facilities to check and calibrate it?
Re: Bristol Wrench
Just have to take it down and replace the flex ring with the upgraded replacement. It's coming apart and plugging the return line. I have good knowledge of working on equipment. Just need to know the proper wrench size.
Re: Bristol Wrench
I'll go for the 0.48 and hope it's right I guess.
Re: Bristol Wrench
Not even close. Oh well I'll try again.
Re: Bristol Wrench
Sorry I didn't see this sooner.
Go here https://bristolwrench.com/product/splin ... -s-291-6l/
It will show you the size. I bought a S-291-6 and a S291-6L Fro, www.mgs4u.com 770-973-6251
Bought all my parts from US Diesel 817-485-6422. Suggest you get multiple Shaft seals in case you turn one inside out on the install.
InJector Pump
P/N JDB435MD2802
JD P/N AR51747 Brad Glen
S/N 4074151 817-485-6422
RPM 2500 www.usdiesel.com
Price Ext Price
1 Seal Kit Stanadyne #24371 $14.62 $14.62
3 Shaft Seal Stanadyne 10453 $1.89 $5.67
1 JDB Pilot Tube (Bushing) Stanadyne #16320 $8.89 $8.89
Pump Vanes Stanadyne #20803
1 20803 use 37268 37268 $14.34 $14.34
Complete Set of vanes Stanadyne 11318
1 11318 Use 7123-19 7123-19 $6.58 $6.58
1 Liner Stanadyne 16753 $11.54 $11.54
Timing Window Stanadyne #13366 $25.85
1 Housing Pr Regulator Valve Stanadyne #15830 $6.83 $6.83
Plastic Governor Wt Vibration
1 Dampner ring Update "EIC" Stanadyne #29111 $51.82 $51.82
1 Drive Shaft Seal Install Tool Stanadyne #13371 $19.98 $19.98
Drive Shaft Oil Seal Install Tool Stanadyne 13369 $27.88 $-
InJector Pump
P/N JDB435MD2802
Price Ext Price
450C Track Loader
291457T
291457T
Re: Bristol Wrench
Thank you very much for the info. I was thinking 0.291 was correct but now I'm sure.
Re: Bristol Wrench
Complete success on the injection pump rebuild. Running much better without all the bits of the flex ring floating around. Even lucked out on the umbrella seals no problem. Was a little apprehensive at first but it wasn't really that complicated.
