Oil sending unit
Oil sending unit
I am having trouble removing the oil sending unit I on a 350bthe top tin can spins but I don’t see or feel a hex underneath near the threaded part. This is diesel 152. Thanks bob
Re: Oil sending unit
Most had a small hex or square for a wrench right up close to the base of the dome, the ones that didn't a place to get a wrench on, I have had to grab with needle nose vise grips under the base or pump type pliers. With pump pliers grab at the base where the dome crimps on and squeeze until it deforms enough it bites the base and turns. You will need a new sender, (which is likely why you are taking it out) as it will likely be destroyed.
Thanks Jim not a lot of room in there hate to pull the start just to get to the sender. New to the forum and the 350 b can’t wait to try and break open track
Users browsing this forum: No registered users and 142 guests
