450c track master pin
A friend with a 1978 450c removed and replaced the track master pin and insists the was no retaining device (snap ring, etc.) to hold the pin--he just drove it out and drove it in. I can't imagine there being no retaining device. Is this possible?
Re: 450c track master pin
The interference fit between the pin and pin holes in the rails hold it.
I have the same thing in the replacement track on my 40c. No problem.
- Jason37756
Pretty common not to have a retainer...most folks tack weld the pin in place to ensure it stays put.
They are an 'interference' fit.
I've removed mine once. I see no danger of it ever coming out on its own.
There is nothing holding any of the other pins and bushings in, drive master is no different.
Users browsing this forum: Google [Bot] and 94 guests
