Good morning all,
when you adjust the steering clutch levers for travel, where do you make the adjustment? the linkage between the lever and spool on the control valve are fixed. I removed the spools and they both look good, it would appear that the oil flow to the clutches is not being blocked to stop the movement of the final drive? at the very extreme travel of the steering levers it will stop the movement, like maybe the brake is stopping the track from moving.
I have been uploading pictures of our 450c to the picture server.
gallery Charlie3939.
450c steering clutches
Users browsing this forum: No registered users and 181 guests
