JD350 Injectors
JD350 Injectors
Hello again, Well after searching for new replacement 9.5mm pencil injectors for my 1969 , all that i find have a fixed threaded fitting attached to the injector side. My originals have a swivel fitting on the injector side and the fuel line side is fixed in place. The part number on the original injector is 17579J5. So are my choices , maybe find original style so as not to play with fuel lines, try to adapt new ends on fuel lines to match up with newer style injectors, possibly have old ones refurbished ( don't like that option ) . I also noticed that originals were calibrated to 3000 psi after market are set to 3200 psi not sure how much of an effect this would cause on performance and accelerated wear on injection pump. Any thoughts ! Steve
Re: JD350 Injectors
Check with Lavoy on this. I think he will be able to fix you up. Otherwise any good Deere dealer should be able to find what you need.
Re: JD350 Injectors
I found the Error in my thinking, the nuts were just rusted solid after 52 years, all is well. Steve
Re: JD350 Injectors
Glad you figured it out.
Users browsing this forum: No registered users and 142 guests
