350CB final drive question?
I have a 350CB in need of a right side final drive assembly. I’ve found one that has been removed from a 350/350B. It is far less pricey than all the others I have found. My question is will it work on my 350CB. It looks identical from what I can see in the pictures. Thank you for your time.
Re: 350CB final drive question?
No they won't interchange between them. The 350C & 350D have wet steering clutches and brakes. The brake anchor for the wet clutch system bolts to the inside of the final drive. The older style dry clutch system doesn't have this. Sorry!!
You can go to jdparts.com and pull up the parts catalogs for the 350, 350B, and 350C where you can compare all the parts. At least some of the major part numbers don't match up (housings, bull gear, spindle). Someone may be along and say it will be ok but I don't think I would not do it without certain confirmation from someone who has made that swap successfully. There were changes between those models, going to wet steering clutches and brakes was a major one. Your 350C has wet steering clutches and brakes. The 350s and most of the 350Bs were dry.You
Looks like LeonardL got your answer while I was typing.
Thank you guys!
Users browsing this forum: Bing [Bot] and 113 guests
