450C transmission fluid and filter change.
Dozer is 450CC, 252285T. I want to drain, change oil and filter(s). It has the H-L-R transmission. Is there just one screen on the right side of the transmission and one filter element in front of the radiator. Is the steering clutch housings and the transmission a common sump, but need drained separately.
Re: 450C transmission fluid and filter change.
Hello,
Yes, you are correct about the screen, filter and common sump. Clutch housings each have their own drain plugs and filler like the transmission (your operators manual provides details). You'll need a new gasket for the screen. Use good oil ( not "303") and some Seafoam if you are worried about moisture.
Mike
Mike
Thanks Mike, I appreciate the response.
Users browsing this forum: No registered users and 143 guests
