Looking for JD 350 steering clutch housing
Anyone know where I can get a right side steering clutch housing for a straight 350 Mine is severely cracked.
Re: Looking for JD 350 steering clutch housing
Have you checked with Lavoy? Have you called any salvage yards? You may want to have your crawler serial number and the casting number that is on your housing in hand. The parts catalog shows a serial number break with two different ones used. I don't remember of hand the difference and am not sure they will interchange. It may have to do with some having different holes for attachments.
Here is a link to the online parts catalog. https://partscatalog.deere.com/jdrc/nav ... ment/62257
I do not have one, I will check with a buddy to see if he has one.
Will one off a 450 fit it?
No, a 450 housing will not fit a 350.
Ok. I have a 450 parts dozer and was going to hook you up but dang the luck.
Try Mark in Johnson Vermont. He used to post here as pondhogvt and regularly has listings in Vermont craigslist in heavy duty equipment for 350 and 450 parts. He had 350C steering clutch housings a couple of years back.
Users browsing this forum: No registered users and 152 guests
