Track Tensioner Spring
I am wondering if track adjuster springs seize up ever. Last year I acquired two used spring assemblies for my 350B. When I redid my steering on the left side and installed a new track I replaced the broken spring with the new used spring. Everything worked fine all season, but I felt like the track idler did not move back and forth very much. Mine seemed to only move around a half an inch based on fresh wear marks. I just felt that was not enough. What would be typical movement?
Re: Track Tensioner Spring
Unless you have the crawler stood on it's nose in the bottom of a hole under extreme load, or run a rock or something through the tracks, I would not expect them to ever move for the most part.
- Al Swearengen
Before I got new pads with relief holes cut, bound up snow would shake your teeth when the chain jumped teeth on the sprocket.
'99 450G 6-Way
I’ve got no worries then. Got too used to my previous broken springs. Thanks again.
Users browsing this forum: No registered users and 140 guests
